Huntindog
Dec 06, 2020Explorer
carringb wrote:The 4 person Hot Tubs I am seeing online hold 210 gallons. That is 1680#Huntindog wrote:
That seems like a pretty tall tale.... But then again the inflatable hot tub you use in your TT seems like an even taller tale
Well, I guess the magical propane fairies must follow me around from RV park to RV park to refill my tanks without me knowing. But I'm not sure how to explain the 4 person hot-tub that shows up anytime I park....
Sorry you guys all have trailers that can't hold heat.
Note: I do run propane heat also when it's teens or colder, because the furnace heats the basement and fire-place doesn't, and I did wake up once to no hot-water when it was 15F over night. It worked again after running the furnace for an hour. But mild-freezing nights it just isn't necessary. Oh and my trailer stays plenty warm into the negative teens, even without skirting or anything other special measures most people need.
44,072 PostsLatest Activity: Aug 23, 2026
