Flip_5's avatar
Flip_5
Small (non-teardrop) Off-road travel trailer
I'm hoping someone can give me an idea if something like this exists. What I'm looking for is a small off-road travel trailer (under 3500lbs), with a single queen bed, an indoor bathroom with shower, and a slide-out outdoor kitchen. I only have found the Black series Classic-12. While this checks most of my boxes, it is a tad bit heavy for my Jeep Wrangler with a max towing capacity of 3500 lbs. I also don't need something quite as heavy duty with the suspension. I most likely won't be going on trails or serious off-roading with it, but want something with a bit more capability than the mass produced offerings like the No-Bo or Geo-Pro by Forest River and the like. Maybe something with Timbren axle-less suspension and large 33" tires. The Classic-12 would be perfect but with a dry weight of 3300 lbs, it doesn't leave much capacity for gear.
Any other options, or am I looking for a unicorn?
Thanks,
Flip
  • Sadly, you are searching for a unicorn, and so am I. Check out the little rig in my signature -- it almost fills the bill, but they don't make it anymore. We take it offroad a lot (carefully), but it is really not designed for that kind of treatment. (It's a Fun Finder X-139 -- if you can find one used, grab it.)
    The other issue is your tow vehicle. Do some reading on Wranglers as tow vehicles, and you will want to cut back on your trailer weight.
    Good luck!!
  • Good luck ! I think you are searching for a unicorn !!
    First, very few travel trailers are TRULY built for "off road". They require extra bracing in the walls and the connection to the floor and roof.
    Is it possible ? Yes, but it would be expensive.
