Hi Mike,
If there is room to add a panel that is certainly the way to go. If there is not room then MPPT may garner an extra 8%. On a 600 watt system that amounts to about 48 watts. 48 watts x 5 hours =~ 240 watt-hour per day. Four days and you have about an extra KWH to use.
When I planned my system panels cost $5.50 per watt, so at that time MPPT made good sense. Now with panels sometimes as low as $0.26 per watt, the only time is where there is simply no more roof real estate to fill.
mike-s wrote:
pianotuna wrote:
One difference is that if you have no more roof space MPPT may allow you to harvest about 8% more.
How much more roof space? Show your math, because I suspect for the difference in cost between PWM and MPPT, you can get more return from adding another panel.
The difference in price between a Morningstar PS-30M (PWM) and a TS-MPPT-30 (MPPT) is about $200. That will easily pay for a 100W panel. So, you'd have to have over 1000 W in panels for an 8% savings to pay off.
