Captain Obvious wrote:
We have a 2007 Jayco 20BH. At 20' long and 6000lbs GVW, its probably about at the top end size wise of what you are looking for. For us its just right - big enough that our family of 3 plus the occasional MIL fit comfortably, but small enough we don't have to worry too much about it fitting. We primarily boondock for 2 night trips and have a great time.
Only catches:
Mod the water tank overflow by adding valves. On some inclines, water will be forced out and you can loose up to 1/3 of your water. Cheap and easy mod.
You may want to flip the axles for better clearance.
I had the less featured 19BH. These trailers are not light but are standard build and heavy so the OP may not have a TV suited to tow it.
We loved the floor plan so much that we upgraded to the same model series and floor plan but with an added queen bedroom on front known as the 26BH. :)
