djsamuel
Aug 24, 2015Nomad
Need-A-Vacation wrote:
Congrats on the new rig!!!
As for a wd hitch, that trailer may not have a lot of tw, but going with a Reese Dual Cam, Reese SC, or Equal-I-Zer 4 Way system can only help the tow experience. You probably would be fine with a side mounted friction sway control, but from what I understand it is highly suggested to remove it before backing up. The systems I mentioned have integrated sway control which do allow backing up. Blue Ox is a newer system that has a growing following. Anderson has a system that also has a following, but it isn't for higher tw trailer (you're fine there), and there is a couple different coupler styles it does not work with. So make sure you research it before buying....
Get a good brake controller, Tekonsha P2 or P3 I think it is.
Don't be afraid to practice with the new trailer in a large parking lot to learn the "quirks" of the new trailer if needed.
Some great suggestions. I'd like to add a recommendation for the Andersen Hitch. We are around 6,000 miles with that hitch and it works very well. We don't have a lot of tongue weight, but it works great for sway and bounce control. Very comfortable tow.
