dadwolf2
Oct 15, 2014Explorer
Big Katuna wrote:
The Mach PS only draws 11.2 on start up. The PS is a special version.
Like I said, people have posted that they have done it. But you can't run anything else. No converter, lights etc. it would be best to pigtail the AC line to isolate the AC load.
The Big Katuna is right!! I had a hard time believing it but I just looked up the spec sheets on the Mach 8 9200 vs the Mach 3 Power Saver. And the Mach 3 PS is a little cheaper. So if the lower profile isn't critical, the Mach 3 PS looks like the way to go.
Mach 8 9200 btu:
Compressor amps 10.1
fan low - 1.0 / high 1.4
totals 11.1 / 11.5
fan high 200 CFM
weight 89.5 lbs
Mach 3 13,500 btu Power Saver:
Compressor amps 8.3
fan low - 2.3 / high 2.9
totals 10.6 / 11.2
fan high 320 CFM
weight 83.5 lbs
44,066 PostsLatest Activity: Apr 10, 2026
