Jesshopes's avatar
Jesshopes
Smelly freezer
Several months ago my daughters failed to empty the camper freezer (unbeknownst to me) and therefore we ended up with rotten meat. We have a Norcold Freezer/Fridge combo. I've tried EVERYTHING I can think of to get rid of the smell. It's better...for sure...but I still smell it. It drives me crazy. Today I decided I couldn't live with it so I starting pricing replacing the unit. Well...that's not in the budget. I'm desperate. I feel like I fill the camper with the smell of rot every time I open the freezer door. EVerything that sits in there gains the smell. I'll take any and all suggestions...
  • Oh, man, that would suck.
    It needs to be mentioned that just any old charcoal is useless for this task. What MIGHT work would be ACTIVATED charcoal, which is cheap enough from most drug stores or online. Get powdered activated charcoal, lay out some plastic wrap, spread the charcoal thinly, and close the door for a week or so. Rinse and repeat. MAYBE that will help.
    Best of luck. That's a VERY nasty problem.
  • Jesshopes wrote:
    EV2 wrote:
    After the obvious of wiping down with bleach, the old method was to keep a pan of fresh charcoal inside to absorb the odor that has gotten into the insulation, etc. Assuming it helps keep changing it often.
    I did try charcoal. It didn't seem to make a big difference. Thanks for the suggestion though.
    We went thru the same thing and never did get the smell out, try these folks as a means to replace
    Refer's
  • After the obvious of wiping down with bleach, the old method was to keep a pan of fresh charcoal inside to absorb the odor that has gotten into the insulation, etc. Assuming it helps keep changing it often.
