BobsYourUncle's avatar
Jun 24, 2017
So when does stuff wear out? Mostly original with high miles
OK, when does my truck wear out?
Just wondering how long this thing is going to last before I start putting a lot into it.....
TV in sig, 07 LBZ/Allison GMC Classic 3500 Dually.
ThIs is my work vehicle, and I tow with it too. Mileage is getting up there, 339,125 Kilometers or about 210,722 miles on it. I don't baby it, if I want to I stomp on it.
Easier to say what has been done to it rather than say what's original. Engine has seen one glow plug until 300000K when I had to put an injector pump in it due to P0087 code - fuel rail low pressure. Oh, and I blew a belt off right after the pump was done. Aside from that, all original.
Aside from usual maintenance stuff and a couple sets of batteries, one front and 2 rear sets of brakes, this thing is ALL original. Yeah, 200,000K on a set of front brakes. Factory front end, all of it, original shocks, exhaust system, wheel bearings, differential etc..... Trans has never been touched. U-joints, everything, all original from when I bought it in August of 2006.
Leaks oil out the Ally, front seal or gasket or torque converter. $2600. to fix it at the stealership. Oils cheaper....
I'm on my 4th set of tires. I run Michelins, first set after I wore out the factory tires gave me 127,000 and somethingK or a little short of 80,000 miles
I change the oil, throw an air filter at it once in a while, grease the thing and drive drive drive it.
And I hate to admit it but I frequently go way past the maintenance intervals. It just keeps on truckin!!
October 18/12, drunk driver turned left right into my path. Nowhere to go, I T-boned him real hard, totally destroying his Mazda. Truck took a $20K hit to the front but I drove it away after taking out a cordless recip saw and cutting the right front sheet metal and stuff from the tire. They suggested writing it off but I refused to let them. Such a good truck, no way I want to part with it.
OK, it doesn't feel quite so tight any more, but it still goes straight and true. Kinda rattles and clunks a bit if I hit rough road bumps, but gee whiz, what an awesome truck it's been!!!!
I almost feel guilty, maybe I should start changing stuff because of all those miles.... yeah maybe I should put some shocks on it. That might tune up some clunks when I go over rough tracks.
I tow a variety of trailers and it still really hauls a$$ when I jump on it. Gets up and boogies it does! No problem keeping up with traffic even with a 10K pound trailer hanging off the back. And I have those big honkin tool boxes and rack with ladders and crud all over it. That's 2000 pounds right there.
Soooooo, when does this thing wear out?
