- W5CIExplorerI have a Honda 3000 Handi and it will not run the AC when set to ECO, it trips out, however running at full speed it works fine,but runs out of gas in 4 hours. no way would I try to run a Honda 2000 for anything except to charge the battery
- BedlamModerator
arto_wa wrote:
mkirsch wrote:
A good friend of mine has had two class C's with Onan generators over the past 15 years.
The current one is brand new, and you have to crank it for over a minute to get it to fire at all, then you have to restart it 2-3 times to get it to stay running. Dealer can't find anything wrong, gave up and says it's normal. Previous one was about 50/50 whether it would run at all.
Maybe you should explain to your good friend that these need fuel to start!
If the RV's propane system has sat unused for awhile it helps lot if the propane line is purged for example by letting "gas" flow out of the stove burner until it is combustible.
Just pushing the starter button, complaining and blaming Onan is another way of purging the line
:h
The gasoline versions have a prime function built in to the start switch. You hold the stop/shutdown switch to prime the fuel line and fill the float bowl prior to starting the generator. Some of the RV manufacturers failed to follow Onan's recommended fuel line length and rise limits - This results in the OEM fuel pump mounted on the generator having to pull fuel too far (it does better at pushing fuel). The solution is to add a second pump close to the fuel tank and possibly eliminate the OEM pump. - BedlamModeratorLPG holds less energy than gasoline, so you should expect greater consumption or less equivalent power output per gallon. Dry camping for three days this past weekend in the mountains with the heat left running and generator getting run two hours each day emptied about half of a 30 lb LPG cylinder (my Arctic Fox has two 30 lb tanks).
There are plenty of places that refill LPG and even smartphone apps that will help you locate the best prices. If you cannot find a refill location, there are plenty of locations that sell or exchange prefilled 20 lb cylinders (yes, 20 lb cylinders fit in my 30 lb location).
On long boon dock trips where we don't plan to head back into town, I usually have my enclosed trailer in tow that carries an additional 100 lbs of LPG. We use these tanks for fire pits and outdoor stoves, but also have the reserve capacity if we need more than 60 lbs of LPG in the TC. - arto_waExplorer
Just pushing the starter button, complaining and blaming Onan is another way of purging the line, but it may take bit longer time!
:h - bighatnohorseExplorer IIWind and rain - inside a cozy camper.
The push button convenience of a generator start beats a Honda any day.
I like POWER and the ability to tap it when needed, instantly.
For me, that's why my camper's will have a built-in propane generator. - WardsterExplorerI keep my Honda 2000 locked up in the rear compartment of my NL and it handles the AC just fine whenever we decide to use it. Fuel consumption is low and I can get gasoline a lot easier than propane.
- bgumExplorerPropane gen will suck a lot of fuel and produce less elect for fuel consumed. Try a Yamaha 2400. It should start and run your AC .
- hbskiExplorerthere is one way to solve the additional fuel issue:
http://www.centralmainediesel.com/triple-fuel-generators.asp
http://www.yamaha-propane-natural-gas-generators.com/
I would not get a built in again, as mine is extremely loud.......even more so inside the camper. - BedlamModeratorAfter 3.5 years, I have 215 hrs on my LPG Onan with no issues. Our previous gasoline Marquis had about 500 hours after 7 years with no issues, but I treated the fuel. Both get run twice a month, so I'm thinking the people that have problems may use them less often.
I would probably look for an alternative if I had a RV without a built in generator. But if ordering new, I will always choose the convenience of the built in. - mkasnerExplorerWe were traveling from Utah to Ohio this past summer, and pulled into a Wal-Mart for a night stay. Outside temp was about 87 however the humidity must have been 90%! Guy with a bigfoot rolls in right after us. While we were inside our 845 sweeting bullets looking at our AC think man it would be nice to have a generator, the bigfoot fired up his generator and it was then that I realized the convience factor on hot muggy days makes it completely worth it.
44,026 PostsLatest Activity: Feb 22, 2025
