Ron3rd's avatar
Ron3rd
Explorer III
Jun 11, 2017
Socket for 2016 CTD front fuel filter cap
Getting ready to change the front fuel filter and am reading many use the 1-1/8" 6-point socket and that seems to work fine, but I'm also reading that the correct socket is actually metric, but getting conflicting info that it is 28mm or 29mm. Which metric size is it for those in the know?
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    IdaD wrote:
    Not sure I'm the metric size. I use a 1 1/8" socket and it it works fine.
    That's what I've been reading too, the 28mm and 1-1/8" are so close it makes no difference. Most important thing from what I've read is to make sure it is a 6-point socket and not a 12-point as the 12 point can round off the corners on the cap.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Learjet wrote:
    '10-'17 6.7L Dodge Cummins engines. Use the 28mm socket on the raised hex on the fuel filter housing.
    '00-'07 5.9L Dodge Cummins engines. Use the low profile, 29mm socket on the raised hex on the fuel filter housing.
    this is good place for info https://www.genosgarage.com/category/tools
    Yeah, that makes sense, the 29mm is for the early caps and the 28mm is for the later caps.
  • Not sure I'm the metric size. I use a 1 1/8" socket and it it works fine.
  • '10-'17 6.7L Dodge Cummins engines. Use the 28mm socket on the raised hex on the fuel filter housing.
