Terryallan
Feb 10, 2020Explorer II
You can also use the 16" concrete paving blocks. Three on each side is long enough for the tandems to fit on. Now If you can't hit the 16" block every time you park, put another set beside of the first set. but you should be able to hit the 16" block. I kept mine on those blocks for years before I had the spot paved.
