joeshmoe's avatar
joeshmoe
Explorer III
May 15, 2017
Soft Spot on Roof
So, I'm cleaning the roof yesterday and take a step back (about 10" in front of AC unit) think I feel a soft spot. I inspect a little further and can't really tell. It's about a 3"X3" area.
I honestly don't know if I'm just being paranoid and it "feels" soft or or if it actually is a bad spot. There's a similar "feeling" area in the camper, on the floor near the sink. I drove my wife nuts with that trying figure out if it was legit. I just let it be and hasn't gotten worse. Who knows. I obviously don't. First-time experience with any of this.
So, What do I do? If it's a leak, I'm gonna be pi$$ed. This camper is only 3-1/2 yrs. old. Which means if there is a leak, it started long before now. Thought these roofs were good for around 10 years?
  • I considered the speaker being about right there, but never realized just how thin the roof wood is. What is that? A piece of luan board? SMH. Still can't believe how cheap the material is. Anyway, Thought I'd pull the AC vent cover inside and take a look for any signs of leaking. Good thing I did. One of the screws had completely backed out.
    Gonna have my wife inspect from the inside while I press down in this area. Just to double check.
    But then I found this:
    Roof Rack Movement
    Sidecar:
    Thanks for the tips. I'll do the pressure test thing.
    I've stayed on top of the caulking on the roof top accessories. Not so much every where else because I've never found any gaps...until this weekend. Could this be a problem or become one?
  • anutami wrote:
    Is your soft spot right about
    Here?
    keep in mind these campers are paper thin and your inside speaker is mounted right here so all of the styrofoam is hallowed out and you have about 1/4" from the top of your roof to the inside of your camper!!! Same goes for your floor :0
    That's EXACTLY where it is.
  • Couple questions first:
    Have you maintained the caulking? Seal maintenance is paramount. I inspect all my seals and caulk every 6 months. This spring when I pulled the unit out of the shop, I was looking it over and I found a gap (not on the roof) but around the outside shower compartment which I resealed and my unit is a year old.
    Truck campers especially suffer from water intrusion in the frontal area (one reason why most builders have gotten away from gasketed windows facing forward, driving in the rain is like being in a tropical storm, the water is pummeling the nose of the camper.
    You could have water intrusion around the AC unit, anything is possible and if it has rot, you won't see it until it starts permeating the ceiling.
    What I'do, especially if you have been lax in checking the seals and caulk is do a blower door test on the unit.
    Camping World offers it (for a fee), it's called a Seal Tite Test (Sael Tite Systems provide the equipment), but you can do it yourself and it's easy to do...
    You need to pressurize the unit and take a bottle of soapy water and go over all the places where there is caulk or seals. The soapy water will bubble, showing an intrusion point. You mark those with a grease pencil and go back and take care of the compromised seals.
    Here's how you do it...
    Take a leaf blower or shop vac on 'blow' and open your pass through window (or any convient window). take a piece of cardboard and put a hole in it for the shop vac hose or leaf blower nozzle and tape that to the cardboard. Tape the cardboard to the window, sealing the opening. Start the blower, make sure all your vents are closed all of them and exit the camper and close the door. The camper will pressurize a bit. Don't take much just a little to get that air coming out through areas of compromised seals. I do mine every year like that and 6 months just going over it visually.
    Hope that helps.
    That will give you a real quick idea of how bad it's leaking and where because rot is a royal PITA to repair and the mold that grows in the wet spaces can be a haalth hazard too.
  • Is your soft spot right about
    Here?
