rpetritsch wrote:
---snip.........
I like the idea of a soft side because of the shorter height for driving down forest roads.
I like the idea of a hard top if I want to stealth camp at a rest stop or Walmart. I would like to know if is possible to use the soft side while the top is down, access to head, refrig. And can you sleep on the dinette with the top down.
...snip..........
Like all of us, you are going to have to make some compromises. If Walmart's are your destination, then a hard side has the advantage. If low height clearance is your main concern then a soft side gives you more.
The newer Palomino soft sides can be used with the top down for everything, although the dinette bed is not that great. Their one button lift system helps with that. Having said that, my next will be a hard side, as I Walmart a lot and use mine for traveling paved highways.
