ScottG
Mar 21, 2020Nomad
2oldman wrote:ScottG wrote:Only if they have user-defined voltage setpoints, including the ability to skip absorb. Cheaper ones usually don't.
Can most of these switch between lead acid and LI if I later choose to upgrade?
What you may be able to get away with using Li's is that they don't care if they don't get fully charged, which may happen if you use the acid profile.
Good to know. If or when I switch over to LI, my solar system will be very small (if I even upgrade it) so I could probably get by with what I have.
44,071 PostsLatest Activity: Aug 30, 2026
