Oregun
Jul 11, 2019Nomad
Solar Charging
Bought my used camper last year and a solar panel was already installed when I got it. My last camping trip I ran the heater overnight for two nights with no problems and was camped under trees so do...
pianotuna wrote:
That is a good way to fry a charge controller.
if you wish to disconnect--put a DC rated switch between the panels and the controller.
The leg from the controller to the battery bank should have a fuse at the battery end.work2much wrote:
You might consider installing a dc circuit breaker between the charger and the battery. Makes it easy to turn off the charger.
