pianotuna
Apr 25, 2013Nomad III
Hi Marc,
I'd buy an elcheapo pwm controller that will tolerate the 24 volt input. Then you can save for the Rogue in the future--and use that money earmarked for a controller to buy the extra panel!
Once you have the Rogue the pwm can be kept as a back up--or sold on ebay.
The other alternative is to go for the Morningstar MPPT 60 amp unit--that would allow for future expansion up to 800 watts. It is more fully features than the 45 amp unit--and is more efficient. Yes, it is a few bucks more, but it also allows for more expansion.
One other alternative is to buy my Blue Sky 3024di. I'm going to have to upgrade when I add the additional panels.
My own panels (4) are in series/parallel. Some folks do go all series, but the "conventional" wisdom is that parallel is a better choice.
If you plan on a combiner box get one big enough to allow you to switch from parallel to series?
44,056 PostsLatest Activity: Jan 12, 2020
