adamis
Sep 17, 2021Nomad II
Many people with more experience then myself for solar but I will throw in my two cents. Having a fiberglass camper, I was hesitant to add any more holes to the roof. I went with these thin film panels by Renogy on Amazon:
https://amz.run/4u4o
I ended up getting some double sided eternabond tape along with the regular onesided eternbond tape and taping the panels to the roof with the double sided tape in the center of the panel (to prevent negative pressure from pulling it off the roof) with regular tape around the edges. About thee years later and thousands of miles and they haven't budged an inch.
Some people on these forums might raise the issue of efficiency loss due to heat because of lack of air-flow and other reasons to go with the rigid and framed panels. While rigid panels generally are more efficient, drilling holes in your roof and adding a complicated mounting bracket system isn't my cup of tea. I will gladly accept losing a few watts to have a cleaner install. They also make these panels in 200W versions so if you have the space on the rough, you just tape the two down for 400w then run your wires. Nothing complicated and no holes to worry about.
44,070 PostsLatest Activity: Sep 18, 2026
