seraphim
Nov 22, 2014Explorer
Thanks for the responses.
I did a little disassembly and under the rubber sking of the roof is 3/8" plywood. Not sure if there is foam insulation under that, the frame components were in the way, but I doubt it - except Joe stated his has the foam... Shouldn't interfere with a well nut expanding, though.
It's going to get up to 50F this afternoon, so probably the best day to put the panel's on; it's only gonna get colder. Deciding to be quick and lazy with wood screws, or use the well nuts and have to drill large holes.
