Paradox123 wrote:
thundercloud wrote:
I mounted two 100 watt panels on the roof over the overhead bunk. One on each side of the Fantastic Vent. I ran the wires to a combiner box mounted to the side and under the refrigerator vent cover. The wires then run down inside the camper behind the refrigerator. The panels were mounted to the roof using stainless steel L style Rocker Feet Mounts and two-sided 3M VHB(vary high bond)tape. I bought the kit from AM Solar awhile ago but I believe they still sell the Rocker Feet. Am Solar also recommends covering the mounts in self-leveling sealant.
This is the approach I took with my install. The VHB tape is pretty impressive. My panels have been on for seven years and are still tight as the day I put the panels on. AM Solar has several videos on YouTube.
My panels have been on the roof for 7 years as well and I have had no problems. When I added the second panel the folks at AM Solar suggested to put Dicor self-leveling sealant around the base of the Rocker Feet to keep dirt and water out. The first panel did not get the Dicor for the first year of it being installed. Still no problems.
