dabedwe
Jul 04, 2015Explorer
solar on/off grid installation
I just bought a nice pull behind camper and would like to install some solar panels on it to make it more self contained as well as tie the system into my home when it is just parked. I have tried to find a video online or even a diagram explaining how to wire this up, but all i can find is off grid installation information for campers and rv's. I want to be able to plug my camper into shore power and still run the solar set up when that is not available. Additionally, i would like to use the panels as a tie in grid system for my house when i am not on the road. I am not sure if i need to buy a separate inverter and install a switch that will cut the power to the camper when i plug the solar panels into my house outlet to feed my home system. I plan on buying an mppt charge controller and 400 to 500 watts of solar panels.
Can i just connect the load to the ac input in on my camper fuse box? i do have a free breaker slot available that i could connect the load to if that will work. If so, can I still plug the camper into shore power while the solar system is running? If i use the free breaker slot, i could just flip the breaker before i plug the camper into shore power if i need to. Additionally, if the breaker slot installation will work, can i use the existing shore plug to feed the power to my house or do i need to cut the feed (basic switch) going to the trailer charge controller from the solar panels, connect them to a second inverter, and then run a new plug from that inverter to plug into my home outlet for tie in use? If i can connect the load to a breaker in the camper fuse box, would i need a separate inverter or could i just run a second load wire with a plug from the charge controller to feed it back to the grid?
I realize there is a lot of questions here. depending on how i need to install this system may make some of them irrelevant. However, I would appreciate any advice on this.
