GULFMAN
Dec 22, 2016Explorer
solar panels
Does anyone know if i can put 500 watts of solar on top of my 2500 9-6 Bigfoot Thanks
SCVJeff wrote:ticki2 wrote:1- If you're referring to my roof, I'm not using anywhere near 34' for my panels, but that is not the point and you are confusing things. This isn't the 1st RV I've owned..SCVJeff wrote:Not many TC's have 34 feet of roof to put things on . As far as I know all of us use our batteries at night .kohldad wrote:where is this rule written? That's about enough to cover self and parasitic discharge..... useless for a real charge cycle. Some folks actually use their batteries at night.
You could but only if you make a rack so they will clear over the vents and skylights. You would not want a panel over the refrigerator vent or cab-over escape hatch. On the roof directly, I think about 300 watts would be the max.
Why do you wamt 500 watts of solar? Usual rule of thumb is 100 watts per battery.
2- Where is it written that the "rule of thumb" is 100w per battery? People looking for install help and not knowing better believe this stuff and it is simply inaccurate.
