Jimbee
Sep 28, 2017Explorer
Solar prep
Hey All, I see many new campers now are coming with a solar plug port outside for portable panels. Do you need to use a charge controller between your panel and the outside plug port or does the on...
How skimpy is the wiring beyond these solar ports?If you're referencing the wire that connects from the RV connection port to the batteries, it will probably be 12 AWG. could even be 14 AWG.
