work2much
Nov 08, 2017Explorer
Solar project thoughts.
Hi guys. Midway through installing. I have the panels mounted and working through wiring. Looking for thoughtful comments. Here are a couple pics of install to date.
centerline wrote:GpnAZ wrote:
Holy smokes, what a bank of batteries and you probably need a bank to buy all those!! What type batteries are you using and what's the weight on all of them? How many total watts do you have for solar panels? I can't help with wiring or monitoring needs but we have some pretty knowledgeable people on this forum when it comes to solar, BKA being one of them. Nice project!
FYI for anyone wiring in a switch...
a switch anywhere between the batts and solar controller that is switched when the panels are producing can be very damaging to the system, mostly to the panels themselves.
properly, the panels should be covered, THEN disconnected with a switch or by being unplugged... or wait until nightfall to disconnect them... there is NO HARM to them setting in full sun and disconnected, but its the switching on or off that can cause damage.
