Aluminum_Siding's avatar
Dec 07, 2015
Solar Question
Hi Folks
First off thanks for the years of helpful replies!
I'm installing solar panels. I can mount my panels on the roof in front running the wiring down to the controller in the storage compartment. From the panels to the controller would be about 15 feet then from the controller to the batteries will be 2 feet.
The second option and would be way more convenient allowing for way better panel placement eg. less potential shading in the late day from one one panel a few feet in front of the other (tilt) or the shroud from the AC etc. It would be on the rear of the roof dropping the cables down only about 10 feet to the charge controller then a couple of feet to the trailers charger. I'd tie in the battery leads to the positive and negative on the back of the trailer's charger that go to the battery. These are pretty thick wires roughly 8 AWG. I understand the first scenario would most likely give me less drop.
My questions is, I've seen several vids and how to's where they tie into the battery wires connected to the trailer's charger and use those wires to transfer the power from the controller back to the batteries. Will the loss due to the distance be of any significance. Is this a recommended way of hooking up. Lets say 8 awg at 20 feet from the trailers charger to the battery bank. Also I have two 6v at 235 amp hrs. I'm only installing 2 100 wt mono panels with tilt brackets. (we dont full time or use any major appliances so this is plenty we actually did pretty well on a 100 wt portable suitcase) Anyway thanks.
