SimonB's avatar
SimonB
Solar research
I want to add a solar system to my camp and was looking for some information. I am still in the process of doing my research but I am stuck on a few items that I cant seem to find any information.
I plan on having all my setup (inverter/charger, mppt, batteries, etc.) in our small shed close to the camp and the solar panels mounted on a stand on our lot. Currently we have two power sources. 12v battery that is charged with a all in on small solar panel and we connect a generator to our shore line from the RV. Of course the small all in one solar panel and 12v would be removed.
First question, i would like to have the solar setup and generator on a automatic transfer switch. I would like to install my transfer switch with the entire setup in the shed and be able to connect my shore line to a plug on the transfer switch. Is this something that can be done? I see allot of people cut their wires and modify the RV breaker panel but I would like to not touch anything on the RV and just use the existing shore line plug.
Second, most inverters/chargers I've looked at have standard plugs (2 to 4) as their outputs. How would I connect this type to the transfer switch to get the full amperage or is this possible. My knowledge is that plugs are either 15a standard plugs or 20a (plug with one prong sideways) so getting the full inverter amperage is not possible unless it has output connections for wire. Is this correct?
Replies have been turned off for this discussion
