Acdii
Apr 22, 2019Explorer
What Sam said above is true. I made the mistake of putting a 6Watt panel on and connecting direct to the battery. All was good for a while and then the battery was DED dead. It killed the battery. Now I have an AGM connected to a smart controller and 15 watt panel. 3 years now and no problems. The only thing to be mindful of is location.
If the panel is not getting full on direct sunlight, it will not produce enough to keep the battery charged! During the winter, being up north where I am, the angle of the sun is too shallow so over time it will draw down the battery instead of charging it. In my situation since I don't need the battery to power anything I just disconnect it instead, and use the panel spring through fall. In fact, just hooked it up last week and in one weeks time the battery is back to full charge.
Now if I can just figure out why the LED strip lighting failed. Only have a couple 4 led groups firing, the rest are all dark.
