For estimation purposes, I would assume about 5 amps of solar harvest where conditions are ideal,
but the nice thing about LFP is that it has a higher charge receptivity rate (compared to wet cell) due to low internal resistance...This means that you’ll get better results with just your one panel, though solar is so inexpensive nowadays (often only about 0.85 cents per watt) I’d recommend at least another panel - but if you do so, try to keep the panel voltages approximately the same, else the higher voltage panel will default to that of the lower one (first, confirm the amp capacity of your charge controller)...The other thing to consider with LFP (LiFePo4) is your factory converter-chargers output voltage...always feel free to PM me if needed.
3 tons
Sounds other thing is
