joerg68
Jun 10, 2017Nomad III
Solved: How to find vacuum leak in water supply line?
Hi all,
this week we picked up our new camper, a Northstar Arrow.
The camper is fantastic and we are very happy with it - except for one problem with the water supply that has us all stumped:
The water pump does not provide constant pressure, sputters, and frequently loses prime. It seems to suck in air somewhere. Especially when we take just a little bit of water, it tends to lose the vacuum and runs dry until we take a lot of water again. Then it primes and works, but sputters frequently. The issue is a bit better when the tank is full, and gets worse as the tank empties.
What we have done so far:
- Checked the tank vent hose - it is free, no kinks or obstructions
- There are no water leaks, anywhere. It holds pressure fine on the pressure side
- All fittings are firm to the touch and dry from tank to pump
- We have switched the winterizing valve and sucked water through the winterizing hose. The effect remains the same.
This would put the problem somewhere between the winterizing valve and the pump (including both), right?
Anyone have an idea how to find the vacuum leak short of disassembling the whole water line from tank to pump? It is made up of around 8 or 10 short sections of solid plastic pipe. And a number of elbows and the one winterizing valve. You can not see if and where any bubbles are introduced. The strainer is installed with the clear lid facing away from us...
To make matters more interesting, we are still on our shakedown trip and have no useful tools with us.
What would you do to find the leak?
