billtex
Jun 04, 2015Explorer II
We have same truck (06) and same setup; SS/bags/5100's. The SS's do make the ride a bit stiff but I would not be without them on a SRW.
Did you try backing off the preload to the first hole?
To be honest, the bags are just along for the ride now on our truck (min psi). I think the 50 psi you are running may be the problem. That is a lot of psi.
IIWY I would out the SS on first hole and remove bags or run at min psi.
We have been running 285's for several years now with no levelling kit (trimmed a tiny bit of the plastic front fascia).
For us, the tires/wheels, SS and Bilsteins have been the ticket with SRW.
Edit; the problem with stableloads and the 2500 for us was the lack of top overloads. This is why the SS were key; additional spring capacity. The weight of our required more spring capacity. Your 861 is probably heavier than our Eagle Cap. Nice camper...but they are heavy.
Bill
Bill
44,056 PostsLatest Activity: Nov 19, 2013
