Bedlam
Jun 04, 2015Moderator
What about using Timbrens or Work Rites between the frame and axle bump stop? You may find a happy medium by using different height spacers that come with these kits. It sounds like your SuperSprings were pretensioned too much when unloaded in order to give you enough support when loaded - There is fine line between unloaded ride comfort and loaded capacity.
The lower StableLoad wedges may give you a 1" lift but it not as pronounced as the SuperSprings. The idea is to pretension your OEM suspension so that heavier loads are supported better.
44,056 PostsLatest Activity: May 04, 2014
