stevemorris's avatar
stevemorris
Some Simple and Important Brake Test
in my brake upgrade attempts ive come up with some simple quick electrical testing for the brake systems on our trailers. these for tests will tell you lots about the electric brake system
So here are four simple brake tests, all done at the 7 pin connector, all pics have the top of the 7 pin toward the top of the picture. I'm using an inexpensive voltohmmeter(VOM), it has a current measuring capacity of 20 amps
first picture is a simple battery voltage test at the 7 pin. black lead from the meter in the bottom right slot(ground), red lead in the top left(12v from tv). my reading is 13.55, normal considering I had just unplugged the trailer from the house
next picture is a resistance measurement of the braking circuit. black in the ground slot, red is in the brake slot. I'm reading 1 ohm, normal for 4-7 inch brakes
next is testing the battery under full braking load. voltage measurement method is the same as the first pic but ive activated the brakes fully with the white jumper wire. battery voltage has dropped which is normal
finally the current draw test. note that the red lead on the meter is moved and note the testlead positions on the plug. i'm activating the brakes through the meter. I'm reading 9 amps which is low, should be 12
obviously since I measured 12 amps without the whip to the truck in the circuit yesterday and 9 with it today, there is a problem in the 7 pin cable somewhere, not unexpected at all
edit: I repeated the last test but used the positive battery terminal for the supply and not the 12v in the whip. black lead in the brake slot of the 7 pin, red lead on the battery terminal. amperage was 12 amps. so the whip is good. the 12v supply wire in the whip is probably only 16 ga, brake wire is probably 12 ga, big difference
  • westend wrote:
    Thanks for promoting the use of a meter. It should be in the tool box of all TT owners.
    Based on my recent "trouble" shooting I would have to add to this that a GOOD and RELIABLE and CALIBRATED meter should be in everyone's tool box.
    A cheapy could throw bad numbers.
  • westend wrote:
    Next, you will need to measure the current and voltage present at the truck's umbilical when brakes are activated. That will inform as to the operation of the brake controller and connectivity to the trailer's brake circuit. Or, more accurately, measure when the umbilical is connected.
    I wouldn't go anywhere without that meter and a jumper wire
    with that little jumper wire you can easily check the lights too. I have been in campgrounds where some had their running lights on all night(not sure why but.....)
    I will be checking the truck's output to the trailer, I will post that too
  • Next, you will need to measure the current and voltage present at the truck's umbilical when brakes are activated. That will inform as to the operation of the brake controller and connectivity to the trailer's brake circuit. Or, more accurately, measure when the umbilical is connected.
