MFL
Feb 28, 2021Nomad II
Lots of ways to figure weight capability, but most times comes down to truck payload limitation, and hitch wt. Overall length will matter, considering wind causing sway. A good WDH helps for sway, and some are designed with this in mind.
Tires will make a difference, some change to LT tires, if P-rated currently. If P-rated, raising PSI, especially on rear will help.
If you can stay within your truck RAWR and receiver hitch rating, it should work. Of course all people, gear, anything in truck, plus loaded to camp hitch wt all take away from your payload. Your payload is on the driver's door, not to exceed xxxx.
Jerry
Jerry
