Gdetrailer
Feb 28, 2021Explorer III
Polishmagnum wrote:
Hello all, new to the forum. A little about my camping setup, I currently have a 2017 RAM Bighorn 1500.
I am looking for some opinions on towing capacity of my truck. It is an 8 speed transmission, 3.92 rear end, crew cab Bighorn. Trailer Life towing guide from 2017 lists its towing capacity at 10140 pounds.
Regardless what "Trailer Life" says..
Need MORE info on the truck.
Regardless of all that "towing capacity" sales brochure or Trailer Life double speak, you actually need to figure out just how much available cargo you have for YOUR truck as it left the factory.
Max towing numbers are typically based from the most bare bones stripped down basic 4x2 regular cab short bed bottom trim levels.. Every option added takes weight away from the cargo giving the vehicle less cargo capacity.. EACH vehicle IS different because of the "options" so no real "cookie cutter" approach can be used.
Trailer tongue becomes "cargo" of your tow vehicle which takes away available cargo from your vehicle.
Several easy ways to get this information.
The newer vehicles now must have a tire/cargo weight sticker which is typically a yellow sticker placed on the drivers side in or around the door post or door. Can't miss that sticker it should be yellow and will specify the max available cargo for that vehicle..
That number should include the weight of fuel plus driver.
Second way is to get the empty or unladen weight of the vehicle, subtract that from the GVWR..
That gets you available cargo weight not including fuel and driver.
Now why the fuss?
Typically what happens is your vehicle will run short on available cargo weight before ever getting close to the maximum towing weight.
Once you have the available cargo weight, you can divide that weight by .15 (15%) and that gets you the max weight you can tow with tongue weight of 15%.
Example, say you have 1200 lbs of available cargo on your tow vehicle..
1200 / .15 = 8000 lbs max towing..
Not familiar with Ram payload packages but typically depending on your vehicles configuration with many half tons, you can see available cargo weights as low as 1000 lbs and as high as 2000 lbs.
The Trailer life numbers you mentioned of 10140 lbs would mean that YOUR truck would HAVE to have 1521 lbs of available cargo, it may, or it may not have that..
Recommended tongue weights for bumper pull are from 10%-15% of the weight of the trailer. For better stability 13%-15% is pretty much where you want to be when loaded.
More for consideration, unless otherwise noted, many trailers do not include propane or battery weights in the tongue weight when shipped from factory on their stickers.. you may need to add those weights in to the tongue weight..
WD systems also become cargo of the tow vehicle, so that also will take away some cargo on the tow vehicle..
As far as figuring in a "safety factor", not a bad idea, it isn't something a lot of folks do, instead they will use the unladen weight of the trailer then add in their guestiment of weight they will haul in order to justify the largest and heaviest trailer they can tow..
Make it easy, just use the GVWR of the trailer as your max weight range you are shopping for(even though you may never use up all of the cargo weight of the trailer).. Doing it this way ensures you have a trailer that is well within your vehicles capability without the need to count potato chips or popcorn kernels..
For instance in my example with 1200 lbs cargo I showed 8000 lbs max, buy a trailer that is 8000 GVWR OR LESS..
Yes, it angers the folks who have found the trailer of their dreams with 3,000 lbs of cargo on the trailer because it will severely limit their size they want, so be it.. better to be safe than sorry.. You want the dream trailer, bump up to a more capable tow vehicle..
