MFL
Feb 28, 2021Nomad II
Just to answer a few questions, yes there are some on this forum towing a 7,500 lb loaded weight TT on this forum, with a 1/2 ton truck. As you know, all 1/2 tons are not equal, and yours with a 15XX payload is on the low side.
You are used to towing near 6K with your truck, and works well. A little longer, and some heavier, you will notice. You may go over your trucks payload number a bit, but not a deal breaker for many.
IMO, the combination truck/trailer will work. All drivers towing are not equal either, one says it tows easily, handles good, does not sway, while the next person, maybe lacking experience, says it was scary to tow. You have the power, and gearing needed, as you likely know.
In the end, you will know after towing. Do I feel comfortable, is my family safe? If you feel unsafe, you can upgrade the truck to a 2,500.
Jerry
Jerry
