Gaffer222 wrote:
Could be the propane detector which runs off the 12volt camper battery. If the voltage is low it beeps.
Old-Biscuit wrote:
From your description of where the detector is located...under dinette.....sounds like a LP Detector. And those are hardwired to battery and will BEEP if battery voltage is low.
CO2 is Carbon Dioxide (what you exhale)
CO is Carbon Monoxide......product of combustion which is another detector and usually mounted up higher. Some are also hardwired to battery but most have their own batteries like smoke detectors.
I think you guys are right - it did say LP on it - Also, I think I meant to say Carbon Monoxide dector.
My battery could be low, but I thought it would be charged by the fact that I'm plugged in to 30 amp shore power. My charger bit the dust in December, and I never replaced it.
But - I have it plugged in - shopuldn't the battery be bypassed when plugged in?
