valhalla360
Nov 16, 2018Navigator
DutchmenSport wrote:
It would be hard to yank out my 5er. With auto self-leveling jacks and 4 slides, before moving, all that would need to be retracted. If the doors are locked, good luck moving it, unless you destroy the front door and destroy the bay hatch to reach the self-leveler controls!
Might damage the levelers but not likely much else just dragging it with forks (assuming they are set up with a hole to go over the pin.
Odds are the slides will survive fine.
Pull a truck camper...first, there is no place to latch on and pull but even if you did, the jacks will likly rip off and then it will be dragging on it's bottom. A couple hundred feet and it may be a total loss.
