searfossExplorerJul 16, 2021Space under slide to add plywood to floorIs there an industry standard as to how much room is under the side room (between the floor and slide room) ? I found a soft spot on the main trailer floor, I fix the leak but would like to stiffen up...Show More
bgumExplorerJul 16, 2021They make an adhesive that is injected into the soft spot and hardens. Not expensive and may be best. Look on YouTube for guidance.
Related ContentStorage and Work Space Near PortlandSpace Heaterreplacing plywood roofZihuatanejo RV space?Bending plywood for roof
