RideSlow's avatar
RideSlow
Spare to match, rotate 5.
Spare to match:
Thinking that I should just buy the 5th tire and get a wheel to match stock. Found one on E Bay that specs in one paragraph 2003 to 2014, and one other place 2009 to 2014. Suggestions please.
Rim Material: Alloy
Offset: +43.18 mm
Hollander #: 2383
Mfg #:
No. Of Bolts: 8
Bolt Pattern: 6 1/2 mm
Finish: super Polished
Structure: 5 Spoke
Condition: new
Available Size: 17x8
Year: 2009-20014
2500 3500 year model 2003-2014 factory oem wheel.
  • I like the idea and have done it on one vehicle but keep in mind that on newer vehicles with tire pressure monitoring you will need get a tire pressure monitor if you are planning to do a 5 tire rotation. I also got a programmer for the TPMS to facilitate changing them out.
    I have used the 'best out of the old set of 4 is the new spare' on some vehicles with success but I have seem many new vehicles that use a different diameter rim for the spare, forcing you to either fork out the money to replace an essentially unused tire every few years or risk a failure as some have described when you do use it. I have also seen a lot of unused spare tires get pulled out of storage only to find that they too are flat.
    A lot of new cars are just giving you a compressor for minor leaks and a phone number for road service for major issues. As few flats as I have had in the last 20 years and given the fact that I always carry a cell phone now I am on the border of saying that is the way to go these days. I hope that it works because my motorhome doesn't even have a place to carry a spare tire.
  • Naio's avatar
    Naio
    Explorer II
    I'm of the 'best out of the old set of 4 is the new spare' school.
    But I guess sun is a big factor. I once drove 250 miles on a donut that had been stored underneath the rig for 25 years, untouched. It did fine
    I kinda laugh at the people who drive around in jeeps with 5 new looking mud tires that have clearly never seen mud and never will.
  • I find rotating in a 5th tire a pain in the ..... Besides it throws off rotation IMO unless one is literally rotating before any noticeable difference in wear front to rear is present. Even still they wear different and putting fronts on the back rotating the right way will shape them back up and vice versa.
    Spare tire if needs replaced, literally costs as much as a couple cases of beer buying off Craigslist. Same deal if you really want a matching rim. There are tons of sets and single take off wheels for sale cheap. A single factory rim of most any sort is relatively worthless and can be had cheaply. No need to buy new.
    Just a couple suggestions.
  • Had a flat the other day in my wife's 1999 Honda so I pulled out the original spare and put it on. Got about a mile down the road and that tire blew up. Went to a tire store and bought two tires. When the tech looked at my blown out spare he said that tire is a 1999 and is just no good anymore even though it has never been on the car. The tire was on a spare rack on the back door covered....Sun and heat killed it !!
  • Still have my original 16 year old spare on the steel wheel. Have used it twice temporarily.
    I had a matching aluminum wheel lined up and was ready to buy five tires that match last time. Wheel auction closed cheep and seller gave some story that it was bent and could not sell it. Was not meant to be. Maybe next time I will try again.
  • We carry two spares and rotate them into the mix every couple of years. Review www.michelinrvtires.com with regard to spares not being used.
  • Have never rotated a spare. And have never had a spare on the ground more than 2-3 times in the last 25 years. And then just long enough to get to a tire store.
