Nvr2loud
Jun 03, 2014Explorer II
Second Chance wrote:Nvr2loud wrote:
What is the loaded weight of your trailer? I would keep the C rated tire if it is rated high enough. My 30 foot, 6000 lb trailer came with B rated tires. I recently replaced with C rated for two reasons....
1) No B rated tires available here
2) Even if B rated tires were available, the maximum of all four tires was reached at 5800 lbs, so the trailer is using the tongue to offload some of that weight... and I don't like the idea of being that close to the maximum all the time. C rated put me at 7000 lbs of maximum tire loading and some load is still off-loaded to the tongue, therefore a nice safety margin.
I've had it on the scales but don't have the info with me at the moment. The specs say 7,753 combining empty weight and NCC, but we weren't anywhere near that coming back from a trip (well below 6,000 if I recall - with 500+ going on the tongue). The current tires are rated at 1,745 each "single" and 1,570 "dual" - whatever that means (I don't know if they mean two axles or dual wheels). Anyway, the lower of those two ratings would total 6,280 for four (6,980 for the higher rating).
If you replace.. I would jump to a D, but if you are replacing the trailer soon anyway... just leave the C rated ones on for now.
