AmericamperExplorerMar 11, 2014Speedo correction for larger tires?When is it necessary to get a speedo correction for larger tires? I went from a 265/75 to a 285/75 both 16 inch. Would the height even change?
trail-explorerExplorerMar 11, 2014Changing the speedo calibration would be needed (if you want an accurate speedo/odometer) when changing tire size
Related ContentCorrect TruckSpeedo Brain teaserLarger wheelsSpeedo/odo recalibration thoughtsConstantly correcting steering
