westend
May 19, 2013Explorer
I'm doing something similar, 1 1/2" conduit under the floor, from passenger's side to driver's side to connect to the distribution center. Fortunately, nothing is in my way except the frame rails and frame gussets.
Is there a chance that you can cut the fabric across the width and add in a support directly over the cut? When you seal it back up you could tape and fasten to your new support. If you really got fancy, both edges of the cut could be bound with metal, covered with a trim piece and you would have an access point in the future, should you need it.
