ticki2
Mar 08, 2020Explorer
Another update . After about 5 years of use one of the ss band clamps developed a small wear hole . They are very thin . I tack welded a heavier gage piece of ss to the wear surface and have had no problem since . They are very easy to remove , just loosen the bolts and slide off the end of the spring . If you go this route measure carefully , the length of the band clamp is important also pe-bend the clamp at the corners around the block and spring so it can be tightened . Good luck with your project .
