LynnmorExplorerNov 27, 2013Spring BushingsI had replaced the plastic bushings with a wet bolt kit. The bushings supplied appear to be oilite material. Oilite has a granular structure and will break easily. The photos are of bushings with a...Show More
time2rollNomadNov 28, 2013I thought the bolt was supposed to rotate inside the bushing. Spring eye should not see any wear or movement.Seems like something may have been wrong with the assembly or equipment when installed.
Related ContentReplace Bushings in Leaf Springs?Replacing leaf spring suspension bushingsF53 front spring bushingsSpring bushingsBushings
