welsteach
Mar 08, 2014Explorer
SRW or DRW?
Considering tc that weighs roughly 3800 dry. Would a 1 ton single rear axle be okay or do I need to look at double axle only. Please, no truck brand wars. Stick to axles. Thanks.
Redsky wrote:
Second option is to replace the factory rims and tires with 19.5 rims and 19.5 tires rated at 4400 lbs. per tire which will cost you about $3500. This will increase the payload up to over 5,000 lbs. but is expensive.
