atvanish wrote:
I think I agree the Dually would be better & more stable.. And yes most of the LQ's are hauled by Duallys... Ours has a slide and such and isn't a small toy. Not sure of pin weight but probably in the 2800-3000 lb range which is way under the 4k or so payload of the SRW.. I really don't need the 6k+ payloads on the duallys. I admit I'm partial to Manuals but concerned (Jealous maybe?) of the extra 150 ft-lbs in the Auto.. ;)
As I mentioned I just find it ironic the DRW 'officially' has less towing capacity. I think either would work for us - just confused as usual :)
your confused because you are really comparing an automatic with a manual not a 2500 vs a 3500 dually. Look at a 3500 dually with an automatic and you will find a significantly higher tow capability than the 2500 automatic
