Vanished's avatar
Vanished
SRW tows more than DRW!
Quite surprised on this one.. Stopped by dealer the other day (yes I'm 'still' looking at new trucks) and found this out...
'13 3500 DRW 4x4 SLT Cummins/G56 and according to the charts it has a LOWER towing capacity w/ it's 3.42's (15,680) vs the '13 Cummins SRW SLT AISIN 4x4 w/ 3.42's as well of 17,150 lbs.
Just dumbfounded that the SRW has a higher tow capacity the DRW I looked at (Admittedly due to the clutch & manual trans).
http://blogs.cars.com/files/2013-ram...500-charts.pdf
Reason I'm looking is either would be fine for todays trailers (7k GVWR dump, 3500lb GVWR utility, 8k GVWR 3 horse slant bumper & 28' 8k GVWR TT) but I might have the need to pull a 14,400lb GN LQ horse trailer and want the ablitity to upgrade to a 5th wheel...
So... Thoughts on Dually vs SRW for a 14k trailer?
  • Yep, a lot of things affect towing capacity.a 4wd generally has a lower capacity because of the weight of the extra running gear. A crew cab long bed has a lower capacity than a regular cab short bed due to the extra truck weight. Generally, a manual tranny is less than an automatic. Lots of things to consider....
  • Dually is more stable and less likely to sway. Also in case of tire failure on rear,you still have one left to hold the truck up.
