Yup...agree with Thomas and add in case no one thought of this for
their chain kit...
5 gallon plastic bucket with lid. Either the once it came with or
after market cover with a cushy top for my tender bottom...am way
older these days... :(
Bucket is a working stool and keeps the salt/slush/etc inside and
NOT on the vehicle rug
2 cans of WD40 to oil down everything going back into the bucket
Below all in their own plastic bags
Chain repair kit with extra links, chain plyers, bailing wire, BIG tie wraps
Chain tensioners. No longer use rubber bands, but truckers version with
coiled spring (about 1" in dia)
Several sets of gloves. Extra thick nitrile (blue that EMT's use)
Roll of hallway vinyl runner in case have to kneel or lay down to get
the back side. Rolled up along the inside dia so not in the way, as
not
used often
$0.99 tools from the hardware store sale table. Plyers (two, one a needle
nose, other lineman with a big wire cutter), screw drivers, etc....toss
them when they get too rusty (not often)
At home, take them all out and hose them down. Hang them to dry and
repeat another coating of WD40
thomas201 wrote:
BenK has got it right. After 30 years in the oilfield mud, sand, ice and snow. I agree with him, it depends. Also the type of ruts if any, and may heaven help you if they used rounded pea gravel on the road. And, is there a dozer or tow truck handy, when you make a mistake.
I have found 4wd and single rears to be the best. Dual rears with 4wd are not bad. Tandems with inter axel locks next (they seem to tear up easy) then single axel duals are the weakest. Lockers really help. By the way, with practice, and working in two man teams, you would be surprised just how quickly you can chain up for bad roads. Say 20 minutes to put on your coveralls, chain up, then strip off your coveralls and have a cup of coffee. I think non 4wd tucks should always have chains, and I often have chains for all four wheels when needed.
Planning is best, and a good pair of well broken in boots, is a good emergency reserve.
