jerem0621 wrote:
I had a 99 V10 3.73, Dually LB CC 2wd...I got about 9.5 empty and 7.5 towing.
How much is the dually MPG penalty? I mean, if my truck wasn't a dually, what would my MPG have been? Would it have been 10.5 empty or more?
Reason I am asking is because we are talking about getting back into RV'ing and I need a truck that can do double duty as a DD at 60 - 70 miles per day. The previous LB Dually had problems in my works parking garage so there is a strong likelyhood that I will have to go with a SRW Shortbed truck.
Thanks!
Jeremiah
Other than a little more wind drag from the fenders and the drag from the two extra tires on the ground I would say around 1 mpg difference at the most providing everything else is equal. Going short bed from long bed will also help too. There would be a bigger difference between 2-4wd I believe. Knowing that you are all about the Ford V10 I really don't believe you will see any difference at all out of that motor.
