HemlingExplorerJul 09, 2020SRW vs DRWAt what weight / length FW is DRW a necessity? Realizing it's very subjective, but is there a consensus? Assuming everything else is equal on the tow rig.
valhalla360NavigatorJul 10, 2020If looking for a rough idea, I would say around 14-16k I would be moving up to DRW.But as others have said, you need to pull the real numbers. Keep in mind it's not just the difference between brands, if you are buying used, the numbers change over the years.
