pressure_welder wrote:
Cummins12V98 wrote:
"2018 montana 305RL - 14,270LBS loaded weight, 2395lbs pin weight
19FT crestliner sportfish - 3800LBS loaded weight/trailer, 300LBS tounge weight. on a tandem axle trailer, 23FT overall length
Don't believe the RV pin weight, is this a fact or a guess??? Boat trailer is light on the pin.
That said if you are at or under your RAWR let er rip!!!
Also truck stops truck, RV stops RV and Boat trailer stops Boat trailer. If it does not have brakes it sure should!
Hey there, those stats on the camper are pulled directly from the placard on the camper itself so i imagine they have to be close
NO they don't!!!
Don't think I have ever seen a published "loaded" pin weight.
20% generally is a minimum and many times 25% loaded pin.
